S32 Design Studio for ARM license expiring in 13 days
31,867 次查看
609510318
S32 Design Studio for ARM license expiring in 13 days,how can i solve it?Thanks!
ActivationId: F625-BD17-9FB6-009D
Evaluation Days: 13
Feature Version: 2.2
Feature Status: Evaluation (13 days)
31,746 次查看
mikedoidge
I have returned your license, when you re-activate, the new expiration date will be loaded.
Mike
68 回复数
9,602 次查看
mikedoidge
Hi Chris,
This license is not expired. As you point out it is valid for 1431 days. What is the issue you are having?
Mike
9,121 次查看
chrislin_wpi
Dear Mike,
I installed the S32 Design Studio for S32 Platform, it shows my license expiring.
Because I didn't get a valid license to install Extensions and Updates.
I had refresh, but it still fail.
I also check my license on the NXP.com website, but it shows Expiration Data is 2026/4/6
9,034 次查看
jiri_kral
I'm not sure what's the issue - if you stretch a little bit the column with Message License Expiring... you will probably see something like this:
Means your license will expire after 4 years.
What particular issue do you have - can you please share a screenshot with error message? Which update/package you can't install?
Jiri
9,028 次查看
chrislin_wpi
Dear Jiri,
Thank you for your explanation.
I can install the Extensions and Updates now.
Best Regards
Chris Lin
9,527 次查看
Bevan
Hi Mike:
can you also help to return my license,thanks!
License Applicable to Product(s): Version Description 2.2 S32 Design Studio for ARM v2.2
License Quantity: 1
Fulfillment ID: 175776437
Expiration Date: Jul 29, 2021
Product: S32 Design Studio for ARM v2.2
Machine: CF30D5D79DD2230677821310B765396A863F0550 Activation
Code: 919B-D4D4-4E64-0434
9,417 次查看
mikedoidge
Hi Bevan,
Your entitlement expiration is in 2025, probably you just need to refresh the license in S32 Design Studio. Also, you could return the license and re-activate. Sometimes it's not possible to do either. If this is the case for you, I can return the license on the server side. Just let me know.
Mike
9,089 次查看
Soonmin
@mikedoidge
Hi mike.
Can you also refresh my license for S32 Design Studio for ARM 2.2 ?
License Quantity: 1
Expiration Date: Jul 6, 2021
Code: 01D6-1D4C-0851-E4A9
I can't return the license, and it is not possible to re-install this software again.
Or, let me know how to re-activate the license.
Best regards.
9,077 次查看
mikedoidge
Your entitlement was already extended. Please re-activate your license using the current activation code.
Mike
9,161 次查看
Bevan
9,751 次查看
stephandewit1
@mikedoidge
Can I get my license renewed for S32 Design Studio for ARM 2.2
A434-2403-BFF4-4364
The license has expired.
Stephan
9,553 次查看
mikedoidge
Hello @stephandewit1,
I have returned your expired license, but the entitlement was already extended. Just re-activate with same activation code and you will receive a new license.
Mike
9,829 次查看
Ai3
Hi @mikedoidge ,
I meet the same question, how can i solve it?
9,336 次查看
mikedoidge
I returned your license on the server, please try to activate using current activation code. It should work now.
Mike
11,135 次查看
jiri_kral
The workaround from license team is just wait till license expires and obtain new license key from NXP download page.
Jiri
8,487 次查看
simonschoenenbe
I have the same problem. Can you please re-activate my licence?
Fulfillment ID: 152126887
Expiration Date: Nov 7, 2021
Product: S32 Design Studio for PA E200
Machine: CB93635434074A5B26076ED3A12D8E2F204A0001
Activation Code: 9441-28CA-C473-A597
8,475 次查看
jiri_kral
I extended your license till end of 2025.
Jiri
10,934 次查看
jackeyhong
Hi Jiri,
I have the same problem. How can I get the new license key from the download page? I can't find any button for the new license.
10,838 次查看
mikedoidge
Hello @jackeyhong ,
I have returned your license on the server, please re-activate the same activation code you already have. It will then show the new expiration date.
Mike
10,775 次查看
jackeyhong
Hi Mlke,
I have re-activated my software sucessfully. Many thanks for you kindly support.
Jackey
10,679 次查看
jiri_kral
I checked your license expiration and your license expires in 2025. You can try Refresh or Return your license:
Hope it helps.
Jiri
10,236 次查看
Sunnny
Hi Jiri,
