S32 Design Studio Installation - Thrown with "You don't have enough Windows permission" error.
Sandy90
While installing S32 Design studio - Thrown with "You don't have enough Windows permission" error. Can anyone help to resolve this issue? Windows "Server" service is enabled. Logs as follows:
__________________________________________________________________________
Thu Nov 02 03:32:15 IST 2023
Free Memory: 43821 kB
Total Memory: 61440 kB
java.class.path:
C:\Users\ITDtpAdmin\AppData\Local\Temp\I1698918274\InstallerData\IAClasses.zip
C:\Users\ITDtpAdmin\AppData\Local\Temp\I1698918274\InstallerData\Execute.zip
C:\Users\ITDtpAdmin\AppData\Local\Temp\I1698918274\Windows\InstallerData\Execute.zip
C:\Users\ITDtpAdmin\AppData\Local\Temp\I1698918274\InstallerData\Resource1.zip
C:\Users\ITDtpAdmin\AppData\Local\Temp\I1698918274\Windows\InstallerData\Resource1.zip
ZGUtil.CLASS_PATH:
sun.boot.class.path:
<none specified>
java.ext.dirs:
<none specified>
java.version == 11.0.11 (Java 1)
java.vm.name == OpenJDK 64-Bit Server VM
java.vm.vendor == AdoptOpenJDK
java.vm.version == 11.0.11+9
java.vm.specification.name == Java Virtual Machine Specification
java.vm.specification.vendor == Oracle Corporation
java.vm.specification.version == 11
java.specification.name == Java Platform API Specification
java.specification.vendor == Oracle Corporation
java.specification.version == 11
java.vendor == AdoptOpenJDK
java.vendor.url == https://adoptopenjdk.net/
java.class.version == 55.0
java.library.path == C:\Users\ITDtpAdmin\AppData\Local\Temp\I1698918274\Windows\resource\jre\bin;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Windows\CCM;C:\Users\ITDtpAdmin\AppData\Local\Microsoft\WindowsApps;C:\Users\ITDtpAdmin\Infineon\LauncherService;.
java.compiler == null
java.home == C:\Users\ITDtpAdmin\AppData\Local\Temp\I1698918274\Windows\resource\jre
java.io.tmpdir == C:\Users\ITDTPA~1\AppData\Local\Temp\
os.name == Microsoft Windows 11 Enterprise
os.arch == amd64
os.version == 10.0.22621
path.separator == ;
file.separator == \
file.encoding == Cp1252
user.name == ITDtpAdmin
user.home == C:\Users\ITDtpAdmin
user.dir == C:\Users\ITDtpAdmin\AppData\Local\Temp\I1698918274\Windows
user.language == en
user.region == null
Installed Feature(s) S32DSF of S32 Design Studio for S32 Platform 3.5
Install Begin: NOVEMBER 2, 2023 3:20:22 PM IST
Install End: NOVEMBER 2, 2023 3:22:15 PM IST
Installed by InstallAnywhere 21.0 Premier Build 6581
User Interactions
#Choose Install Location
USER_INSTALL_DIR=C:\\NXP\\S32DS.3.5
#Choose Shortcut Folder
USER_SHORTCUTS=C:\\Users\\USER\\AppData\\Roaming\\Microsoft\\Windows\\Start Menu\\Programs\\NXP S32 Design Studio\\S32 Design Studio for S32 Platform 3.5
#Install
-fileOverwrite_C\:\\NXP\\S32DS.3.5\\_S32\ Design\ Studio\ for\ S32\ Platform\ 3.5_installation\\resource\\iawin64_x64.dll=Yes
-fileOverwrite_C\:\\NXP\\S32DS.3.5\\_S32\ Design\ Studio\ for\ S32\ Platform\ 3.5_installation\\resource\\iawin32.dll=Yes
-fileOverwrite_C\:\\NXP\\S32DS.3.5\\_S32\ Design\ Studio\ for\ S32\ Platform\ 3.5_installation\\resource\\win64_32_x64.exe=Yes
-fileOverwrite_C\:\\NXP\\S32DS.3.5\\_S32\ Design\ Studio\ for\ S32\ Platform\ 3.5_installation\\resource\\remove.exe=Yes
-fileOverwrite_C\:\\NXP\\S32DS.3.5\\_S32\ Design\ Studio\ for\ S32\ Platform\ 3.5_installation\\resource\\invoker.exe=Yes
Summary
Installation: Unsuccessful.
32 Successes
0 Warnings
1 NonFatalErrors
1 FatalErrors
Action Notes:
None
Install Log Detail:
Check Disk Space: C:\NXP\S32DS.3.5
Status: SUCCESSFUL
Additional Notes: NOTE - Required Disk Space:4,454,120,040 Bytes Free Disk Space:407,766,990,848 Bytes
Status: SUCCESSFUL
Get Registry Entry: Key: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\VirtualizerRuntime-M-2017.06-171108
Value Name: InstallLocation
Status: SUCCESSFUL
Get Registry Entry: Key: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\VirtualizerRuntime-M-2017.06-180110
Status: SUCCESSFUL
Get Registry Entry: Key: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\VirtualizerRuntime-M-2017.06-180223
Status: SUCCESSFUL
Get Registry Entry: Key: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\VirtualizerRuntime-M-2017.06-180403
Status: SUCCESSFUL
Get Registry Entry: Key: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\VirtualizerRuntime-M-2017.06-180720
Status: SUCCESSFUL
Get Registry Entry: Key: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Uninstall\{4b12c27c-689d-42cd-a475-ba2c4fdd2e2b}
Status: SUCCESSFUL
Status: SUCCESSFUL
Additional Notes: NOTE - Required Disk Space:4,454,120,040 Bytes Free Disk Space:407,762,956,288 Bytes
Install Directory: C:\NXP\S32DS.3.5\jre
Status: SUCCESSFUL
Install JRE: C:\NXP\S32DS.3.5\jre
Status: SUCCESSFUL
Install Directory: C:\Users\ITDtpAdmin\AppData\Local\Temp\867272.tmp\
Status: SUCCESSFUL
Additional Notes: NOTE - Directory already existed
Execute Command: NET SESSION
Status: SUCCESSFUL
Execute Command: ping 1.1.1.1 -n 1 -w 5000
Status: SUCCESSFUL
Install Uninstaller: S32 Design Studio for S32 Platform 3.5(Install All Uninstaller Components)
Status: SUCCESSFUL
Install Directory: C:\NXP\S32DS.3.5\_S32 Design Studio for S32 Platform 3.5_installation\resource\
Status: SUCCESSFUL
Install File: C:\NXP\S32DS.3.5\_S32 Design Studio for S32 Platform 3.5_installation\resource\iawin64_x64.dll
Status: SUCCESSFUL
Install File: C:\NXP\S32DS.3.5\_S32 Design Studio for S32 Platform 3.5_installation\resource\iawin32.dll
Status: SUCCESSFUL
Install File: C:\NXP\S32DS.3.5\_S32 Design Studio for S32 Platform 3.5_installation\resource\win64_32_x64.exe
Status: SUCCESSFUL
Install File: C:\NXP\S32DS.3.5\_S32 Design Studio for S32 Platform 3.5_installation\resource\remove.exe
Status: SUCCESSFUL
Install File: C:\NXP\S32DS.3.5\_S32 Design Studio for S32 Platform 3.5_installation\resource\invoker.exe
Status: SUCCESSFUL
Make Registry Entry: Key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\S32 Design Studio for S32 Platform 3.5
Value Name: EstimatedSize
Value Data: 426ec7
Status: SUCCESSFUL
Status: ERROR
Additional Notes: ERROR - Error writing LaunchAnywhere components (Access Denied)
Uninstall Folder: C:\NXP\S32DS.3.5\jre
Status: SUCCESSFUL
Delete File: Source:s32ds.bat
Status: SUCCESSFUL
Additional Notes: NOTE - Source file s32ds.bat does not exist.
Status: SUCCESSFUL
Delete File: Source:Welcome.txt
Status: SUCCESSFUL
Additional Notes: NOTE - Source file Welcome.txt does not exist.
Remove Registry Entry: 5 HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\null
Status: SUCCESSFUL
Error occurred while installing the following Action, hence rolling back the installation....!
Action Name: Trigger Rollback Action
Action Description: Trigger Rollback Action
Error Details as below:
This action rolls back the Installation.
Can someone please help to resolve this issue?
Mehul_Patel_NXP
Hi, @Sandy90 ,
Please make sure that you have administrator right privileges while installing the S32DS.
If you are having issue with administrator privileges please also check with your company's IT team, if firewall blocking or any other issue.
Please follow this guide for activation:
 https://community.nxp.com/t5/S32-Design-Studio-Knowledge-Base/HOWTO-Activate-S32-Design-Studio/ta-p/...
Please follow the S32DS guide while installing S32DS: https://www.nxp.com/webapp/Download?colCode=S32DSIG
If you are still having issue. Please update us.
Thank you. Best regards.
- Mehul Patel
Mehul_Patel_NXP
Hi, @Sandy90 ,
Last week there was some server issue, please can you retry installation.
Thank you. Best regards,
- Mehul Patel
