S32 DS install fail——rolling back
1,936 次查看
Qingguo
When install S32 DS,always appear rolling back error;before Software Activation Code;pls help to solve this problem;THKS!
4 回复数
1,684 次查看
hicensezhang
Hi, I met the rolling back problem , could you have resolve the problem?
1,914 次查看
Qingguo
When I  close the 360 software,it can be installed successfully!
1,931 次查看
Robin_Shen
Hi Qingguo,
Seems that you are attempting to install to a PC using an account which is not part of the Administrators security group. This is listed as required in the installation guide.
Please contact your IT require higher admin privileges.
Robin
1,927 次查看
Qingguo
@Robin_Shen Thank you for your feedback;But this install was in my personal PC,and the user admin privileges!Then I try it again in admin privileges,but it always failed!
