Hello @raghuramdc ,
First question, is your login ID a member of the administrator's group on this PC?
Second question, is it possible to set the temp directory to another location? It could be that it doesn't like the unusual characters in the current path.
From the log file:
'System's temporary directory = C:\Users\RaghuramDC(GCT-IN)\AppData\Local\Temp'
'Errors: 'C:\Users\RaghuramDC' is not recognized as an internal or external command,
operable program or batch file.'
Perhaps you could try to remove the TMP environment variable and then install S32 Design Studio and afterwards add the TMP variable back?
Mike
