S32 DS debugger cant register
1,122件の閲覧回数
Kunal_Gupta
Hi all,
I am using S32DS and having S32K312-EVB board. Running the port example sketch, but during the debug configuration it asks for registration. But on doing so, error like this comes up:
What is the solution for it? I have installed the software again, have make sure that all relevant drivers are installed.
Would be looking for reply as early as possible.
1,099件の閲覧回数
mikedoidge
Hello @Kunal_Gupta
You do not need to register with P&E. This only enables them to have your email address to contact you with product notifications, etc. There is no impact to your ability to use S32 Design Studio or the P&E GDB debugger. It also does not impact the support you receive from NXP or P&E.
The error appears to indicate the Eclipse environment is unable to access the internet to load the P&E registration page.
For further questions on this, I would suggest that you contact P&E Micro.
Mike
