S-record (S2 v S3)
Search instead for
S-record (S2 v S3)
jackboatman
Using S32DS for MPC5777C. Default /example project. In Properties>ToolSettings>CrossSettings I have Create flash image checked. Under create flash image>General I have Motorola S-rec selected. When I build I get the s-rec. But it is always S2. How can I get S3?
jackboatman
Fantastic, that does it. Thank you very much.
jackboatman
I would be happy to try that. But I do not know where I would put that line / command; hardware guy writing test code.
alexanderfedoto
jackboatman
Fantastic. Thank you.
Jack
alexanderfedoto
Have you tried "--srec-forceS3" ?
jackboatman
Thanks, I’d be happy to try, but I don’t know where to put that line/command; hardware guy writing test code.
Jack
