Hello all,
I'm migrating my MPC5602P device software from CCW to S32DS Power.
In fact, I'm using asm("bne btd") to branch (in case if non zero flag exists) to
asm("btd:") ;
XXXX;
looks like there is something wrong in assembly code which actually seen in Disassembly Section. Below is the screenshot for the same
Also, it resets once the asm(""bne- btd") instruction executes.
Kindly help in this regard.
Solved! Go to Solution.
Hello all,
Solved from thread Branch Instruction for S32DS Power.
It is actually the problem with the assembly instruction.
Raju
Hello all,
Raju
