RTC with s32k344
RTC with s32k344
4,270 次查看
janakiraman-NTL
Hi Team,
I added the RTC driver for s32k344 but encountered some errors. Can you help me resolve them?
Janakiraman
4,252 次查看
danielmartynek
Hi @janakiraman-NTL,
The channel must be selected in GptHwConfiguration
BR, Daniel
8 回复数
4,253 次查看
danielmartynek
BR, Daniel
4,249 次查看
janakiraman-NTL
Hi Danial,
"Thank you for the reply.", The error was gone.
Can you provide an example code for setting up RTC, getting the time, and using the alarm feature on the S32K344 microcontroller?
Thanks & Regards,
Janakiraman S
4,246 次查看
danielmartynek
Hi Janakiraman,
Have a look at the examples here:
https://community.nxp.com/t5/S32K-Knowledge-Base/S32K3-Low-Power-Management-AN-and-demos/ta-p/152772...
BR, Daniel
4,243 次查看
janakiraman-NTL
Hi Danial,
Thanks, I will try and let you know
4,236 次查看
janakiraman-NTL
Hi Danial,
I am unable to open the .mex file and view the configurations on S32 Design Studio version 3.5. Could you provide the latest version of the example code?
Janakiraman
3,820 次查看
Akhil1
Hello
I am working on S32K312 and I want to make S32K312 to go to standby mode and need to wakeup using RTC timer for 5 sec.
after going to standby mode...need to wakeup after 5 sec automatically.
can you please help me regarding this and share any project examples.
Akhil
3,796 次查看
danielmartynek
Hello @Akhil1,
Some S32K312 examples can be found here:
https://community.nxp.com/t5/S32K/s32k312-RTC-not-working/td-p/1512153
Please create a new thread if you have any questions, this one has been closed.
4,229 次查看
danielmartynek
Hi Janakiraman,
We don't have any newer versions of the projects.
You can install S32DS 3.4 with RTD 2.0.0.
BR, Daniel
