S32K14x devices have 2 RAM regions named SRAM_U and SRAM_L. They are arranged in continuous manner. E.g.: S32K142 has the following RAM regions: 1FFF_C000 to 1FFF_FFFF and 2000_0000 to 2000_2FFF.
The linker scripts shipped with an SDK has separate memory segments for them:
/* Specify the memory areas */
MEMORY
/* SRAM_L */
m_data (RW) : ORIGIN = 0x1FFFC000, LENGTH = 0x00004000
/* SRAM_U */
m_data_2 (RW) : ORIGIN = 0x20000000, LENGTH = 0x00003000
m_data is used to store code that should be in RAM, .data and interrupt vectors.
m_data_2 is used to store .customSection, .bss, heap and stack.
Since there is no gap between the sections, it feels natural to me to merge them into a single segment.
E.g.:
MEMORY
/* SRAM_L + SRAM_U */
m_data (RW) : ORIGIN = 0x1FFFC000, LENGTH = 0x00007000
This will make easier to manage big arrays, since you will have single RAM segment.
Are there any undesired consequences?
The only undesired consequence I can imagine of is unaligned access on the edge.
E.g.:
*(int32_t *)0x1FFFFFFF = 42;
But such reads/writes should be avoided in any case.
Thanks and regards,
Maksim.
解決済! 解決策の投稿を見る。
Yes, misaligned accesses across that memory boundary will cause a hard fault. There has been a discussion on that topic at the end of the following article:
FreeRTOS Heap with Segmented Kinetis K SRAM
I hope that helps,
Erich
I am working on S3k148 controller and faced the similar issue. I required more .bss section so modified the linker file accordingly.
Existing RAM split-up:
/* SRAM_L */
m_data (RW) : ORIGIN = 0x1FFE0000, LENGTH = 0x00020000
/* SRAM_U */
m_data_2 (RW) : ORIGIN = 0x20000000, LENGTH = 0x0001F000
Modified:
/* SRAM_L */
m_data (RW) : ORIGIN = 0x1FFE0000, LENGTH = 0x0003F000-0x2000
/* SRAM_U */
m_data_2 (RW) : ORIGIN = 0x2001D000, LENGTH = 0x00002000
I have enclosed the complete linker file for your reference. The memory consumtion in bss in crossing the boundary region and still I did not face any issue of hard fault.
Can I know the reason for hard fault not occurring. Looking at the above comments, I am supposed to get "Hard Fault" which has reduced my confidence level.
Can you please advice.
Hemadri
I hope that helps,
Erich
Hi Erich,
Thanks! That helped very much.
I had the very same problem: FreeRTOS heap allocation, so I ended up modifying the linker script to allocate all the regular .bss, .data, interrupt vector table, heap and stack in SRAM_U, and reserve the whole SRAM_L region for FreeRTOS heap.
Maksim.
Hi Maksim,
in that case you probably will find that one interesting too:
Using Multiple Memory Regions with the FreeRTOS Heap | MCU on Eclipse
That way you can have multiple memory regions used by FreeRTOS.
I hope this helps,
Erich
