I am having a try to use S32DS 3.1 ConfigTools to make a configuration for S32G274A.
I have installed the internal device package for S32G, see below picture:
And after I launched the ConfigTools with below selection:
The DCD tool seems can not be opened:
I want to confirm if the DCD tool available in this version?
Thanks.
Solved! Go to Solution.
1. File->New->S32DS Application Project, Select S32G274A Cortex-A53
2. Select "S32 Configuration Tool"
3. ConfigTools->DCD
4. You are welcome :smileyhappy:
Dmitry
3. ConfigTools->DCD
Dmitry
