Question of S32DS by KEA
1,558 次查看
Luke_Chun
Hello Team
I have a question of AN5213SW for KEA that AN5213SW is implemented by S32DS.
I’m trying to migrate from S32DS to CW 10.X because of customer requirement.
At this time, I cannot fix one issue.
I copied the C, H and S files from S32DS project of AN5213SW to the making new project by CW.
As you can see the below picture, it is making the error by “__START”.
However I don’t know how to use "__START" into S32DS.
My question is
1. Could you let me know how to use “__START” into S32DS?
2. How to fix this problem?
3. If you have any guide about the migration from S32DS to CW, please provide it..
Thank you.
1,330 次查看
stanish
Hello Luke,
__START is a macro defined in S32DS Assembler Settings -> Symbols. It's equal to __thumb_startup() which is the same entry point as in CodeWarrior.
So the solution could be to add this symbol into CodeWarrior GCC assembler -> Preprocessor -> Add a defined symbol.
Hope it helps.
Stan
