Problem with S32 Design Studio for Power v1.2 - Update 2
3,750 次查看
jobu
I get some error messages if I try to install the update. Please see attached file.
Some hints to fix the problem are welcome...
Jörg
3,551 次查看
jobu
... I finally manged the update. I have disabled all URLs in "Available Software Sites" and then it works.
Jörg
3,552 次查看
jobu
Jörg
3,552 次查看
jobu
... I have switched off the firewall but no difference. Also my network connection is fine.
Other suggestions?
Jörg
3,552 次查看
jiri_kral
Hello Jörg,
I updated S32DS right now and have no issue with that. In your case it may be some temporary network outage or firewall issue on your network. If the errors are still present - check the firewall settings and network connection.
Jiri
