Printf in FreeRTOS
Printf in FreeRTOS
3,167 次查看
jay_zhang
Hi Jiri,
Thanks for your reply, I check the LPUART1 config, I think it is correct, I uploaded my project, can you help to check why I cannot print the serial port?
标记 (4)
1 回复
2,465 次查看
jiri_kral
for some reason isn't the low level I/O function
__write_console(__file_handle handle, uchar_t * buffer, size_t * count)
called by calling printf(). I'll do more investigation and let you know.
Jiri
