Possibility to install the keil compiler v6.62 on S32DS
755 次查看
AdithyaJayaram1996
we're planning to install the KEIL MDK V6 Professional UBL (Compiler version V6.22) within the S32 DS 3.5 IDE environment. Has anyone successfully integrated this toolchain with S32 DS? Is this configuration supported?
If so, could provide any documentation or guides detailing the setup and configuration process? Any help or pointers would be greatly appreciated.
Thanks in advance!
3 回复数
708 次查看
jiri_kral
unfortunately Keil compiler is not supported in S32DS. Default compiler is gcc and S32DS supports IAR, GHS and WindRiver compilers via plugins.
S32DS is based on Eclipse, it is possible that you will be able find Keil integration for generic Eclipse.
700 次查看
AdithyaJayaram1996
As you mentioned  S32DS is based on Eclipse and there might be generic Eclipse integrations for Keil, has anyone tried adapting such solutions within S32DS? Any documents available on how exactly that needs to be done & What are the challenges or limitations encountered?"
684 次查看
jiri_kral
I didn't met anyone who uses Keil with S32DS and unfortunately there is no such documentation.
