NXP S32148 C++ start-up code and linker script
1,843 次查看
saireddy_saredd
Can Any body provide me startup code and linker script for Nxps32k148 micro controller for C++ ??
I have the startup and linker script for C code but I hvae problem with C++. For C++ code ctor is not allocated.
Sai
标记 (4)
1,734 次查看
alexanderfedoto
Hello saireddy.sareddy@gmail.com
What S32DS version do you use ? Default S32DS Application project supports C++. Perhaps you modified source somehow.
Could you please share your project ? You can cut off your proprietary code if necessary.
1,733 次查看
ErichStyger
Specialist I
Hi Sai,
It depends on the (GNU) library you are using. You might have a look at C++ with Kinetis Design Studio | MCU on Eclipse. But basically check your startup code and insteas of calling directly main() call the library initializer function(s).
I hope this helps,
Erich
