MTRDEVKSBNK144_S32DS firmware
1,828件の閲覧回数
aash92
In MTRDEVKSBNK144_S32DS firmware,why TRGMUX output 2,TRGMUX output 3 and TRGMUX output 6 in Trigger MUX Control is used and how this works in this firmware?
as i also attached the firmware
i looked in reference manual but i didn't find any description for TRGMUX output
ラベル(2)
2 返答(返信)
1,721件の閲覧回数
danielmartynek
These three triggers FTM3 init, PBD1_ch0, ADC1 COCO are routed to PTD1, PTA0, PTE15 for debugging purposes only.
You can measure the control loop FTM -> PDB -> ADC on external pins.
The TRIGMUX_OUTn are pin functions that can be used as a target module of the TRIGMUX.
1,721件の閲覧回数
aash92
Hi Daniel,
Thank you for clarification :smileyhappy:
