this error looks more related to debugger than compiler. Can you share more details - like output from debug console? Do you have custom board or NXP EVB? If you have custom board - what is your debug probe?
Jiri
Thanks for replying so fast.
I have the EVB.I am basically trying to light a rgb on my board with an example source code.After i debug i get this
Um - never seen such error before. Is your board recognized by OS - normally you can see another disk drive named EVB-s32k144
Jiri
yes ,it is recognized.I tried to change the cable but i get the same error.
Did you modify the project (or debug session settings) or it is fresh unmodified example? Did you use these steps - build project, open debug configuration
choose your debug config and click on Debug:
Jiri
