How to use iseled library at s32k116
ソリューションへジャンプ
1,951件の閲覧回数
kimmk
I use s32 design studio for ARM ver. 2018.r1 and processor is fs32k116lit0vfmt.
I changed MCU package 48pin(default at s32k116 pjt) to 32pin.
But how to use iseled library. it's version is indicated as s32k144_sdk01.
I choose SDK_S32K1xx_15/timing_pal when it added.
so can't choose data & clk pin match on s32k116_32.
What can I do for using correct iseled library version at s32k116_32?
タグ(2)
1,919件の閲覧回数
Julián_AragónM
Hi @kimmk,
It is necessary to install corresponding S32K1xx SDK before installing ISELED SDK. There is description about how to match version between S32K1xx SDK and ISELED SDK in the
“S32K1_ISELED_RTM_x.x.x_ReleaseNotes.pdf”, which is included in ISELED SDK package.
Julián
1,920件の閲覧回数
Julián_AragónM
Hi @kimmk,
Julián
