How to use iseled library at s32k116
kimmk
I use s32 design studio for ARM ver. 2018.r1 and processor is fs32k116lit0vfmt.
I changed MCU package 48pin(default at s32k116 pjt) to 32pin.
But how to use iseled library. it's version is indicated as s32k144_sdk01.
I choose SDK_S32K1xx_15/timing_pal when it added.
so can't choose data & clk pin match on s32k116_32.
What can I do for using correct iseled library version at s32k116_32?
Tags (2)
Julián_AragónM
Hi @kimmk,
It is necessary to install corresponding S32K1xx SDK before installing ISELED SDK. There is description about how to match version between S32K1xx SDK and ISELED SDK in the
“S32K1_ISELED_RTM_x.x.x_ReleaseNotes.pdf”, which is included in ISELED SDK package.
Julián
Julián_AragónM
Hi @kimmk,
Julián
%3CLINGO-SUB%20id%3D%22lingo-sub-1910874%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHow%20to%20use%20iseled%20library%20at%20s32k116%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1910874%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3EI%20use%20s32%20design%20studio%20for%20ARM%20ver.%202018.r1%20and%20processor%20is%20fs32k116lit0vfmt.%3C%2FP%3E%3CP%3EI%20changed%20MCU%20package%2048pin(default%20at%20s32k116%20pjt)%20to%2032pin.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBut%20how%20to%20use%20iseled%20library.%20it's%20version%20is%20indicated%20as%20s32k144_sdk01.%3C%2FP%3E%3CP%3EI%20choose%20SDK_S32K1xx_15%2Ftiming_pal%20when%20it%20added.%3C%2FP%3E%3CP%3Eso%20can't%20choose%20data%20%26amp%3B%20clk%20pin%20match%20on%20s32k116_32.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EWhat%20can%20I%20do%20for%20using%20correct%20iseled%20library%20version%20at%20s32k116_32%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1911576%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20How%20to%20use%20iseled%20library%20at%20s32k116%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1911576%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F158196%22%20target%3D%22_blank%22%3E%40kimmk%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EIt%20is%20necessary%20to%20install%20corresponding%20S32K1xx%20SDK%20before%20installing%20ISELED%20SDK.%20There%20is%20description%20about%20how%20to%20match%20version%20between%20S32K1xx%20SDK%20and%20ISELED%20SDK%20in%20the%3CBR%20%2F%3E%E2%80%9CS32K1_ISELED_RTM_x.x.x_ReleaseNotes.pdf%E2%80%9D%2C%20which%20is%20included%20in%20ISELED%20SDK%20package.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EJuli%C3%A1n%3C%2FP%3E%3C%2FLINGO-BODY%3E
