How to solve the warning: No grammar constraints (DTD or XML Schema) referenced in the document.
4,291件の閲覧回数
chen1834
Hi experts,
As mentioned in the title, how to solve the warning "No grammar constraints (DTD or XML Schema) referenced in the document." IDE is S32 Design Studio for Power Architecture 2017.R1.
I believe it's related to Eclipse settings but cannot find out the specific reason and solution. Can anyone help me on it?
Thank you!
ラベル(2)
タグ(3)
4,201件の閲覧回数
stanish
Hi Chen,
I suspect this could be caused either by corrupted installation or some coruption within the active workspace.
Could you possibly try switch to a new clean workspace and check. If it does not help I'd suggest to reinstall S32 Design Studio for power:
S32 Design Studio for Power Architecture v2.1 (Windows/Linux) released!
https://community.nxp.com/docs/DOC-345897
. If the problem persist could you post some screenshot of the error context?
Stan
