How to restart a S32 Design Studio debug session?
4,226 次查看
yulianmatev
This is my configuration:
  • IDE: S32 Design Studio
  • Debugger: PE micro
  • Device: MPC5748G
Is there a way to reset target during a S32 Design Studio debug session so software starts from its beginning? Idea is to skip all the time needed for chip erasing and software re-loading in case this is done by “Terminate” and “Debug” buttons.
I already know that there is a powerpc-eabivle-gdb console which supports some commands, but I am not able to find the right one. Seems that command “target reset” is not supported.
Yulian
s32ds power debug reset
3,544 次查看
martin_kovar
Hi Yulian,
try command monitor reset instead of target reset.
Martin
3,544 次查看
OliverTian
 You can also use mouse to get the restart.
  In 'Debug' window, right click mouse on main(), you will find the 'Restart' icon on the popped menu, as the snapshot of below.
Cheers!
Oliver
3,545 次查看
martin_kovar
Hi Yulian,
Martin
3,544 次查看
yulianmatev
Hello Martin,
Command monitor reset seems to do what I was looking for.
Thank you!
Yulian
