How to know RAM memory consumption for application on S32K144 EVB
6,596 次查看
mrajanna
I have attached .map file for one of the application.
From .map file I extracted below information.
Memory sections
Size in bytes
.data
2436
.text
11320
.rodata
48
.bss
316
I would like to know how much RAM memory will be used when this application run on S32K144 MCU ?
Is there any provision in S32 design studio to monitor amount of RAM used when debugging this application on S32K144 evaluation board ?
Mohan
Original Attachment has been moved to: S32K144_CSEC_KEYCONFIG_Example.map.zip
标签 (2)
标记 (4)
5,278 次查看
jiri_kral
you can enable printing target size by right click on project name -> properties  and check the Print size checkbox
In build console you can see something like this:
Here is detailed description of each block (text, data, bss...)
Jiri
4 回复数
5,279 次查看
jiri_kral
Jiri
5,278 次查看
mrajanna
Hi Jiri,
Thank you for the information.
From your experience can you please suggest how much of RAM is required in below scenario.
Use case Scenario:
   a. freeRTOS
   b. Load secure key to CSEc + Perform encryption and decryption on plain text using loaded secure key + Prepare for       secure boot.
   c. Run OBD CAN stack
   d. Other hardware initialization if any
Mohan
5,278 次查看
jiri_kral
well - I have no idea how many RAM your project will need - it depends on implementation. But I'm sure that 64kB of RAM on S32K144 is okay for your scenario.
Jiri
5,278 次查看
mrajanna
Hi Jiri,
Okay.
If you can share any sample project details like what all components were running on S32K144's 64K SRAM, it will be helpful to me.
Mohan
