How to import KEAZ128 Lab examples project to S32D ? compile and debug
2,180 次查看
colinzou
I Fist use S32D,could not import examples project to S32D ?please help
4 回复数
2,041 次查看
stanish
I'd recommend you to create a new project and transfer the source files manually.
Or you can check the examples delivered with S32 Design studio (File -> New -> New S32DS project from template):
Hope it helps.
Stan
2,041 次查看
colinzou
Hi Stanislav Sliva,thank you a lot,But I already had a example in other folder.
I dont know how to import these projects.
2,041 次查看
stanish
1) go to Menu File -> Import
2) Select General\Existing Projects into Workspace
3) select directory with the examples:
Select which individual examples you would like to import (you can physically copy the projects into workspace) and press Finish button.
4) finally the projects should appear in your workspace
Hope it helps.
Stan
2,041 次查看
colinzou
   Thanks a lot
