How to generate .hex file in s32design studio with extended linear address(Record type 04)
3,303 次查看
sreevishakhkp
As we are trying to generate .hex file, default its generating with record type as Extended segment address( type 2) .We need .hex file with extended linear address(type 4).Please let me know any changes need to be done.
Thanks in Advance.
Sreevishakh
标记 (3)
3,143 次查看
jiri_kral
Hi Sreevishakh,
it looks that arm-none-eabi-objcopy can generate only Type 2 intel hex or at least I didn't find way how to force i32hex output. As a workaround you can use external srecord tool:
SRecord 1.64
and convert .hex output to i32hex by:
srec_cat.exe test.hex -intel -o i32_test.hex -Intel
console command.
Here is result example - on the left is .hex file generated by S32DS - on the right output from srec_cat tool:
Hope it helps.
Jiri
3,143 次查看
sreevishakhkp
Thank you Jiri
