How to generate Project_xxx.ort file for OSEK RTOS awareness in S32DS?
453 次查看
JhonYF
I'm working on an OSEK-based project in S32 Design Studio, and I want to enable RTOS Awareness debugging. The tool asks for a file named xxx.ort, but I don’t have this file and couldn’t find clear documentation on how to generate it.
What tool is used to generate .ort files for OSEK?
Thanks in advance!
标记 (1)
1 回复
436 次查看
stanish
Can you possibly provide some additional details describing your setup:
1) which MCU are you targetting?
2) which version of S32DS are you using?
3) which tool are you using as the OSEK builder?
Typically The ouput from OSEK builder is the configuratuion .h files and the ort file for OS aware debugging
Hope it helps.
Stan
