How to download more than one *.elf files
2,944 次查看
yuehedeng
   I use s32DS+ MPC5748G. I have separate project for boot loader and main APP, so I also have separate *.elf files.  My question is how to download two of them at one time?
2 回复数
2,696 次查看
stanish
Please try to add your bootloader .elf as the additional .elf file into the main core debug configuration.
This allows you to program both .elf files and debug just the Application elf:
You can do the same for bootloader debugger configuration, and the debug information for bootloader is available instead of app:
Hope it helps.
Stan
2,696 次查看
yuehedeng
Thanks very much. It works.
