How to correctly step debug in S32DS ?
1,596 次查看
pingfang
I am developing millimeter-wave radar using S32R274. Now, I want to debug the code step by step through PE . But, the program does not follow C syntax.
The version of IDE is S32 Design Studio for Power Architecture Version 2017.R1. And, I have set it in S32DS, but it doesn't work. Please see the figure below for the specific setting.
Ping
标记 (4)
1,381 次查看
stanish
I'd recommend you to clean the project and rebuild it again.
Could you describe more in the detail "...program does not follow C syntax..."
Feel free to post some debugger screenshots that show the problem you are facing.
Stan
