How to convert exist S32DS project to IAR 8.3x
Search instead for
leo_wu
Hi NXP
I am testing can_pal demo code from s32ds, but customer is using IAR 8.3.
I have follow your guide to setup IAR manager on S32DS and convert a NEW project to IAR is ok.
but I don't know how to convert a exist project to IAR, such as S32DS demo code?
could you give me some idea?
stanish
Hi Leo,
If the existing project example is intended to GCC build tools, there is no easy way to migrate into IAR.
In order to be able to migrate such a project from S32DS->IAR the project has to be created for IAR toolchain.
So I'm affraid the only way is to install the IAR Eclipse plugin and create a new project for IAR toolchain and then
transfer all the source files/ SDK configuration into this new project.
Hope it helps.
Stan
