I'm using the DEVKIT-MPC5744P,my IDE is S32DS for Power Architecture 2017.R1;I cannot using PE in S32DS,the menu "add to project" is disable.
I can't find how to add component in PE.please help.
Your project is not based on SDK. The processor expert is part of SDK. You can add SDK when new project is created:
or you can add SDK in existing project as well (right click on project name -> Properties) :
When done, your project should look like this:
Hope it helps.
Jiri
