How to Reset MCU in S32 Design Studio with S32 Debug Probe
Tianxiang_Huang
Hi team,
I saw there is an article in the community knowledge base, by @stanish. very nice.
https://community.nxp.com/t5/S32-Design-Studio-Knowledge-Base/HOWTO-Reset-MCU-in-S32-Design-Studio-d...
I followed the guide and found the reset button is active by using the PE debugger.
But when I use S32 Debug Probe
https://www.nxp.com/design/design-center/software/automotive-software-and-tools/s32-debug-probe:S32-...
that reset icon is always inactive when I debugging the code, do you know can S32 Debug Probe support reset?
stanish
I did some investigation and unfortuntely there is no easy way how to perform in-target reset by debugger using S32 Debug Probe. Especially in multi-core debug environment.
It is recommended to restart debug session instead of resetting the target.
See attached the list of known limitations related to scripting.
Hope it helps.
Stan
stanish
Hope it helps.
Stan
Hello Stan,
Is it planned in future releases to address this issue and add a feature that can perform in-target reset by debugger using S32 Debug Probe.
Tianxiang_Huang
Hi Stan,
I understand, Thanks for the clarification.
BRs,
Tianxiang
