How it is possible to create a txt file in s32 design?
1,569 次查看
p_decesare
I want to create a txt file with s32 design. For the moment, I see the value of the variable on the console of s32 design studio for arm. But I want to create a txt file for the storage of the values.
How it is possible? I tried to use fopen and the library <stdio.h> but I don't have success and there are some problems.
Thanks for the help
Paola
1 回复
1,552 次查看
jiri_kral
Hi Paola,
I'm afraid, that S32 DS doesn't support output from Semihosting console into file. But you can copy content of console and paste it into text editor - for example. Other possibility is printing over UART and store output on PC machine.
You may find helpful this article: https://community.nxp.com/t5/S32-Design-Studio-Knowledge-Base/How-to-use-printf-function-in-S32DS-fo...
Jiri
