How can i show the peripheral register configuration in S32Design Studio?
5,408 次查看
pietroserao
Goodmorning, i'm working with an S32144K microcontroller. How can i show the register configuration?
There is any register tool different from the processor expert?
Thanks.
标签 (2)
标记 (3)
5 回复数
4,914 次查看
BlackNight
Hi Pietro,
there is EmbSys Registers view (menu Window > Show View > Other) you can use for inspecting the registers:
I hope this helps,
Erich
4,915 次查看
pietroserao
Thank you, but i can't read the registers values.
There is something to setup?
4,915 次查看
BlackNight
Hi Pietro,
you need to double click on the entries to read it.
There is an article with details about the original open source plugin and its usage here: How to Add Register Details View in Eclipse | MCU on Eclipse
I hope this helps,
Erich
4,915 次查看
guoht
Hi Erich:
   How to change the registers value?It doesn't work when I changed one bit or more.
4,915 次查看
pietroserao
thanks
