How can I see change trend of variables when debugging a project in S32DS
已解决
跳至解决方案
2,696 次查看
XU_Boost
Hello everyone,
    I can see real time changes of variables when debugging a project in S32DS,  but I can't record them, any tool or plug-in can record them and show their trend in a graph dynamically?
1 解答
2,673 次查看
Robin_Shen
Hi Michael,
As far as I know, currently S32DS does not support this function, but you can use FreeMASTER to achieve it.
https://community.nxp.com/t5/FreeMASTER/bd-p/freemaster
Robin
在原帖中查看解决方案
4 回复数
2,665 次查看
jiri_kral
Real Expressions monitor is PE Micro plugin and there is no record feature (may be PE Micro add it in future).
As Robin mentioned - FreeMaster is one possibility. Other one is using Segger J-Link debug probe and use J-Link scope tool.
Jiri
2,588 次查看
XU_Boost
Hi, Jiri
Sorry for my late reply, thank you for providing another possibility by using Segger J-Link debug probe and use J-Link scope tool. but it's very pity I currently only have PE Multilink. I didn't find PE Micro plugin with record function before, but now FreeMaster tool can help me, thank you!
2,674 次查看
Robin_Shen
Hi Michael,
Robin
2,593 次查看
XU_Boost
Hi,Robin
I'm sorry for my late reply, this tool is very helpful, thank you!
