How can I customize my own MIPI camera
1,678 次查看
hnxiaojuzi
I want to use AR0231 as my MIPI camera,I don't how to customize it.Can you give some suggestion?
thank you all.
标记 (3)
1,484 次查看
jiri_kral
there is already example in VSDK v1.1.1 RTM for AR0231 located in [YOUR_VSDK_INSTALL]\VisionSDK_S32V2xx_RTM_1_1_1\s32v234_sdk\demos\isp\isp_ar0231_max9296b_csi_dcu\
You can look at it as a reference.
Hope it helps.
1,484 次查看
hnxiaojuzi
   I have read this reference,but I don't have max9296b ,how can I only use ar0231 to grab frame.
