How can I add the makefile pluings into S32 DS?
1,163 次查看
raulcastanon
I would like to use the S32 DS IDE to view the .makefile .cmake .bat files and be recognizable by the editor as eclipse does when installing those plugins... How can I update the editor installing those plugins?
标记 (2)
1 回复
1,067 次查看
BlackNight
Hi Raul,
I'm not sure if I understand? Eclipse already comes with the default plugins to view make files/etc: if you open them in the editor, they recognized as such and color coded.
It would be good if you could provide more details about what you mean?
Best,
Erich
