Failure for configuring GDB
1,950 次查看
hrfbit
When using 32DS to load the program, it is stuck in GDB and cannot be performed. Why?
Error in final launch sequence
Failed to execute MI command:
-target-select remote localhost:7226
Error message from debugger back end:
localhost:7226: ϵͳÊÔͼ½«Çý¶¯Æ÷ºÏ²¢µ½ºÏ²¢Çý¶¯Æ÷ÉϵÄĿ¼¡£\r\n.
1,458 次查看
stanish
It seems you are trying to run the debugger configuration for non-boot core (hello_z4_2).
I'd recommend you to run the debug using launch group for the multi-core projects:
For more details please see e.g. this document: https://community.nxp.com/docs/DOC-335367
Hope it helps.
Stan
