Expression watch window not updating during runtime in S32 Design studio for Power Architecture
SudharsanGK
I would like to hear from you the following.
Expression watch window is available in "Window" Menu. Its not updating the Global variables while debugging the code. when debug stops, it gets updated. Kindly let me know how to enable the same.
Important Note: Its for "Power Architecture" not ARM
lukaszadrapa
Hi @SudharsanGK
this feature is available only for ARM devices in S32DS. In case of MPC5xxx devices, it's supported by hardware/MCU but not by S32DS (PE). The only option is to use advanced debuggers (like from Lauterbach...).
Lukas
SudharsanGK
Got it. Thanks
