Error after deleting D_Cache_Enable in the option of S32K312
1,651件の閲覧回数
HyunungPark1
Currently, I use S32 Design Studio for S32 Platform and S32K312,
I delete "D_CACHE_ENABLE" option in the S32 Design Studio for S32 Platform.
The hard fault error happens when C40_IP_read is called like the attached file.
Could you please let me know what should I do to resolve this issue?
1,619件の閲覧回数
lukaszadrapa
Hi @HyunungPark1
if data cache is disabled, you should disable cache synchronization. Could you give this a try?
Lukas
1,620件の閲覧回数
lukaszadrapa
Hi @HyunungPark1
Lukas
