Dual wire to Single wire CAN conversion in S32k144
b_mansoor
I want to convert the data from dual wire CAN (500kbps) to single wire CAN(33.33kbps). How to implement this in software?
PetrS
using FlexCAN module there is no difference, just CAN bit rate must be modified.
Different transceiver must be used, like https://www.nxp.com/products/interfaces/can-transceivers/legacy-can/single-wire-can-transceiver:MC33...
BR, Petr
jiri_kral
what is your chip used for physical layer?
Jiri
