I want to convert the data from dual wire CAN (500kbps) to single wire CAN(33.33kbps). How to implement this in software?
using FlexCAN module there is no difference, just CAN bit rate must be modified.
Different transceiver must be used, like https://www.nxp.com/products/interfaces/can-transceivers/legacy-can/single-wire-can-transceiver:MC33...
BR, Petr
what is your chip used for physical layer?
Jiri
