am using Multilink and OpenSDA to check the value of the variable through the Real Time Expressions tool. It is not successful to use JLINK here. Please help to confirm whether the plug-in function supports the JLINK debugging tool. Thank you
as far as I know, real time expressions is part of PE Micro plugin and is not supported by Segger J-Link.
Jiri
ok,thanks for your answer.
never-displayed
