Could not connect to semihosting port due to connection timeout. Please check that the correct port
3,881 次查看
p_decesare
Hi, I  have a problem. My code doesn't work because on the console I have this problem:
Could not connect to semihosting port due to connection timeout. Please check that the correct port number is configured.
How could I repair this problem?
My code worked perfectly, but now I have this problem.
Can someone help me?
Paola
2,206 次查看
Drifter22
Same problem for me with v.3.5. All has worked until yesterday, then today this error appears.
3,851 次查看
jiri_kral
what's your S32DS Version and MCU?
Jiri
2,847 次查看
steven_zhang
Contributor V
i have the same problem  ,S32DS3.4    P32K344EHVPBS1P55A
