can you please share more details? What is your target MCU and S32DS Version?
For correct build you need S32DS Application Project
It is possible that you created C/C++ project. For debugging is best option Debug Configurations and choose your debugger and start debug session.
Jiri
I am importing the existing project.
Now.. I tried compiling. Using miscellaneous options in C/C++ build I am using --save-temps option.. It compiled successfully.
But processor expert code generator is not working to set pin configuration.
When you import the project - are there some warning messages - like Some version of SDK is not available? Such type of issues are mainly caused by importing project based on older SDK.
Jiri
Jiri
