Hi, @BlueZhang ,
Please can you check now if you enough licenses or not.
Thank you. Best regards,
- Mehul Patel
Hi @Mehul_Patel_NXP ,
I am experiencing the same issue depicted above, but with my own licence (Fullfillment ID 197733417). Can you please help me? I would like to reinstall S32DS in the same machine.
Also, what is the correct procedure so that this does not happen again?
Thank you!
Hi, @BlueZhang ,
Please can you let us know the activation code you are using so that I can check.
Thank you. Best regards.
-Mehul Patel
Hi, @BlueZhang ,
- Mehul Patel
