Build a project
Build a project
4,302 次查看
Anjalipurushothaman
While building a project , only one target option is enabled, which make to only debug the configration.
If I need to flash the program into target processor , which has to be selected . (PE Micro is not poping up in the Run configration window)
wheras while debigging , i can selecte PE Micro.
Since toolchain will be same for any target proessor, Hope anyone can provide solution to this.
4,235 次查看
Anjalipurushothaman
Yes, That is correct
4,267 次查看
VaneB
Hi @Anjalipurushothaman
Please correct me if I am wrong.
What you are trying to do is flash your micro with your debugger, but you do not see the "release" option, you only see "debug"? Am I correct?
B.R.
VaneB
4,236 次查看
Anjalipurushothaman
