Basic example project file for GHS
1,989 次查看
leekate-b45752
Could I get an basic example project file for GHS with S32K14x?
Kate Lee
标记 (3)
1,820 次查看
mikedoidge
Hi Kate,
You will first need to contact Green Hills to get the Eclipse Neon compatible plug-in. Then, after you install the plug-in, you should be able to use the New Project from Example wizard to see the Hello World example included in the SDK. Alternatively, you could use the New Project Wizard to create an empty project.
Mike
1,820 次查看
jiri_kral
Hi Kate,
unfortunately I don't have any GHS examples for S32K144 - hope that someone on community will share something.
Jiri
