Any way to make 4 spaces instead of tab in S32DS IDE?
3,698 次查看
cheukeichoy
I'm using S32DS for ARM to program S32K144 project, and I don't think the S32DS editor is friendly. I want to use 4 spaces instead of the tab symbol, but when I set it up, it doesn't seem to work. It still shows the tab symbol. Have you get any idea to turn the tab symbol into 4 spaces?
Setting:
Result:
Cheukei
标记 (1)
3,478 次查看
BlackNight
Hi Cheukei,
See Spaces vs. Tabs in Eclipse | MCU on Eclipse : you have to change the code style too.
I hope this helps,
Erich
3,478 次查看
cheukeichoy
Hi, Reich,
      it work, it's useful. Thank you for your help.
Best Regards
Cheukei
