An internal error has occurred.
steven_zhang
An internal error has occurred while tried to add drivers such as flex_pwm to the project using Peripheral config tool .
mikedoidge
Hello Steven,
I was able to reproduce your issue. An internal ticket has been logged for this issue. I hope to have some solution or workaround for you soon.
Mike
steven_zhang
i add the flexio_mcl before adding the flexio_pwm,error is disappeared .
there is another question:
  does  the " TRGMUX_IP_INPUT_SIUL2_IN4" signal ruted to "TRGMUX,IN ,4 "directly?
