About Fatal error[Li001]: could not open file error
2,181 次查看
Hoon
I am using IAR workbench. Now when i compiled my project code, below error message occured.
Fatal error[Li001]: could not open file "D:\SVN\Model\trunk\project\App_IAR\Debug" (failed opening file: 액세스가 거부되었습니다.)
Where to find this file and how I can fix this?
In addition, I received the setting environment from co-worker, but I'm the only one having a problem.
IDE : S32 Design Studio for ARM Version 2.2 / MCU : S32K144
2,140 次查看
jiri_kral
please check if you have write permission in D:\SVN\Model\trunk\project\App_IAR\Debug folder. It looks, that S3DS is not able write output files there. Also create new workspace may fix the issue.
Jiri
