hello,
when i import the example of the SDK, there are a lot of "semantic error" reported by the IDE . could you please help to check this issue. i already had installed the S32DS_PA_v2017.R1_UP7.zip
thanks and regards
qingzhou
hello Rares
i try to rebuild the index as your guide, but it do not work.
thanks and regards
qingzhou
Can you try to rebuild the indexer (Project > C/C++ Indexer > Rebuild)?
Let me know if it worked.
Rares
